99 XLT missfire
Old Jan 21, 2009 | 04:50 PM
jeanette656's Avatar
Default 99 XLT missfire
Hi there, I have a 99 XLT V-6, cel came on and read a missfire on 4th cly, I replaced the plugs and wires to no avail,(plugs all looked fine)and for the heck of it replaced the fuel fiter, any ideas what I could try next? Am I right in assuming the 4th cly is the front drivers side? Thanks for any ideas you can give!!
Old Jan 25, 2009 | 09:21 AM
Use Common Sense's Avatar
Default RE: 99 XLT missfire
Could be a bad coil pack. Check to ensure that the coil connectors are clean and remove coil pack, clean the grounding surface and reinstall the coil pack to see if it clears the problem. If not, I would lean towards a bad coil pack.
rotten65
Sep 15, 2011 11:50 AM
jwdshell
Sep 3, 2011 09:05 PM
batty2044
Apr 19, 2011 03:16 PM
gdowle
Sep 11, 2008 05:32 PM
dell
Feb 14, 2006 07:46 PM
