Service Engine Soon EGR Valve
Old 08-13-2007, 10:46 AM
crimey617's Avatar
Default Service Engine Soon EGR Valve
2002 Ford Explorer-the Service Engine Soon light came on. I checked the code and it indicated a faulty EGR valve. I replaced the EGR valve and reset the computer but the light came back on within 200 miles with the same code!!! Any idea what could be causing the service engine light to come on again with the same code even AFTER I made the repair?
Old 08-13-2007, 01:41 PM
Default RE: Service Engine Soon EGR Valve
Check and see is the passage between the EGR and the intake is clean, the passage from the exhaust to EGR is clean, with some carb cleaner, and a wire or somethng to try to run through the tube. Also the vaccum line might be restricted/leaking.
Old 08-13-2007, 10:42 PM
Replace the DPFE sensor! Trust me on this one.
Old 08-15-2007, 09:52 AM
crimey617's Avatar
What is the DPFE sensor and where is it located?
Old 08-15-2007, 12:09 PM
Differential Pressure Feedback Exhaust Gas Recirculation ..
#2 in the diagram..
[IMG]local://upfiles/6756/D56FBE84D2874339A8E9D8611324B9B2.gif[/IMG]
[IMG]local://upfiles/6756/501D3672A37F406F875F10AF806DED1E.gif[/IMG]
Old 08-15-2007, 01:46 PM
wheelsup68's Avatar
Another vote here for the DPFE sensor, and carry a spare.
tootsie
11-08-2006 12:52 PM
marklar81005
10-11-2006 01:00 PM
rascall142
09-16-2006 07:53 AM
Doyle
03-31-2006 12:18 AM
AbNormal27
02-24-2006 12:12 PM
Quick Reply: Service Engine Soon EGR Valve
