| makuloco2000 |
Mar 29, 2014 07:24 AM |
If the vehicle battery is replaced, carry out the Battery Monitoring System Reset using the scan tool. If the Battery Monitoring System Reset is not carried out, measurement data collected for the old battery is not deleted and future state of charge measurements will be inaccurate. For example, if an old battery has a state of charge of 60% and the new battery has a state of charge of 90%, the BCM will recognize battery state of charge being 30% lower than it actually is. With the battery state of charge being perceived lower than it actually is causes shedding of loads earlier than is necessary. This also impacts the smart regenerative charge system by causing the battery to be maintained at a higher state of charge than perceived by the BCM, reducing fuel economy benefits.
