Ball joints 04 explorer
Are these fairly easy to do they dont look to bad to change ????
RE: Ball joints 04 explorer
Hi, the upper table is pretty easy, you might have a little problem with theupper tablebolts to frame, but you should go thru it!. For the lower ball joint, you want to remove the knuckle/spindle, what ever how you call that. Then, using a stand or a jack, you support the lower table, remove the snap ring and using an hammer you tap the ball joint downward.
Nic. |
How about control arms?
| All times are GMT -5. The time now is 05:45 AM. |
