-   Ford Explorer (https://www.fordforum.com/forum/ford-explorer-20/)
-   -   blower problem (https://www.fordforum.com/forum/ford-explorer-20/blower-problem-10413/)
wfooofc Nov 6, 2007 08:36 PM
blower problem
the heat or a/c blower is not working in the front of my explorer(98), but is blowing in the rear of the suv.i replaced the relay last fall,also swapped some of them around.i am just not sure what the problem is.
Hayapower Nov 7, 2007 12:58 AM
RE: blower problem
Is it standard climate control, or EATC (electronic automatic temp control) ?
cral Nov 12, 2007 11:32 AM
RE: blower problem
are you getting cold air up front just not heat? or vice versa
burr Nov 14, 2007 02:41 PM
RE: blower problem
I have a similar problem in my 98 explorer and it has EATC (front blower works on high only heat or air) rear manual selector works fine.
cral Nov 14, 2007 06:16 PM
RE: blower problem
if its what i think its your blend door to fix dealer will charge 1500-2500 for it or you can buy part on ebay for 20 and do it yourself
burr Nov 14, 2007 07:30 PM
RE: blower problem
I can change the temprature (but it only works on high), so I was thinking itmay not be the blend door???
Burr
Hayapower Nov 14, 2007 11:23 PM
RE: blower problem
Might be the blower motor speed controller mounted in the evaporator case under the hood..
burr Jan 6, 2008 02:10 PM
RE: blower problem
Thanks for the info, I got around to changing out the blower motor speed controller and it works fine now.
