differential fluid on a 1997 XLT
Old Aug 14, 2009 | 10:27 PM
graveyard's Avatar
Default differential fluid on a 1997 XLT
im helping my buddy replace his diff fluid, and i need to know a couple things, mind you im a Volkswagen guy.
1 how much fluid?
2 what type of fluid?
3 there is only a diff in the rear correct?
i think it will be pretty self explanatory, but any tips or a right up would help.
thanks in advance.
Old Aug 15, 2009 | 07:03 PM
graveyard's Avatar
this forum blows
graveyard's Avatar
maybe if i up the post someone will look
Old Aug 15, 2009 | 07:04 PM
graveyard's Avatar
and 4
Old Aug 17, 2009 | 06:13 AM
Use Common Sense's Avatar
Does your BUDDY have an owners manual? If so, the required information is located on pages 223-224. Is your BUDDY's 1997 Explorer a 2WD or 4WD? If 2WD, then it has one differential, if 4WD, then it has two. Anyways, here you go...
Capacities and specifications
Front axle fluid Motorcraft SAE 80W90 Axle Lubricant 4 x 4 vehicles 1.7 (3.5 pints)
Rear axle fluid1,2,3,4 Motorcraft SAE 80W90 Axle Lubricant Vehicles with conventional
Axles 2.9-3.1 (5.50-5.80 pints) Motorcraft SAE 75W140 High Performance Synthetic Rear
Axle Lubricant Refer to footnotes 2 and 3.
1 Fill to 3 mm (1⁄4” to 9/16”) below bottom of fill hole.
2 Vehicles equipped with 4.0L SOHC and 4.0L EI engines may have a limited slip differential. If
your vehicles is equipped with a limited slip differential, add 4 ounces of additive friction modifier
C8AZ-19B546-A, Ford specification EST-M2C118–A, for complete refill of 8.8 inch and 9.75 inch rear
axles.
3 Vehicles equipped with 4.0L SOHC or 4.0L EFI engines and 3.73 or 4.10 rear axle ratios or 5.0L engines require synthetic rear axle lubricant. Rear axles containing synthetic lubricant are lubricated for life. These lubricants are not to be checked or changed unless a leak is suspected, service required or the axle assembly has been submerged in water. The axle lubricant should be changed any time the axle has been submerged.
1960nick
Oct 8, 2012 09:18 PM
madmaxed69
Jul 31, 2009 06:49 AM
ra_dost
Apr 30, 2007 07:53 PM
Luke 22
Jan 29, 2007 08:34 PM
Ramtour2
Oct 12, 2005 11:41 AM
