DRL problems
2000 explorer drl will come on work for few mins and then start blimking after a few more mins will start flashing like hazzard lights shut off expl and they continue to flash only way to stop is to pull 15amp fuse under hood all other lites seem to work the way they are suppose to. could it be a bad sensor or photocell and where are they located? any ideas sure would be a help thanks wolf234
RE: DRL problems
sounds like bcm problem to me although i would have to look at the scamatics first. Does anyone have a wiring scamitic for the daytime running lamp circuit. I believe the bcm would have to be flashed at ford after replaced although not 100% Hope this helps. good luck
RE: DRL problems
thanks for info but being new to this not sure of all terms used please explain "bcm" so far ford dealerships have been no help again thanks wolf 234
| All times are GMT -5. The time now is 09:57 AM. |
