Ford chrome 20 inch rims corroding
Old 12-15-2018, 09:29 AM
ExplorerDriver's Avatar
Default Ford chrome 20 inch rims corroding
My 20 inch chrome rims have and issue... the clear coat has come off in areas and the aluminum is beginning to corrode. Is ford going to address this? Replacing 4 rims is a bit of $$$
Old 12-23-2018, 09:39 AM
am i the only one with this propblem?
Old 12-23-2018, 11:25 PM
Use Common Sense's Avatar
Well, questions to are are...
What year vehicle?
Where do you live (Salt belt?)
Are the original tires still on the rims?
Been thru any mechanical car washes?
If you live in the salt belt you'll have exposed the rims to salt and sandblasting on the outer lips of the rims so environment would most likely void any warranty.
If replacement tires have been installed, the clearcoat may have been breached by the removal and installation of the tires by the tire machine operator (Touch-less doesn't always mean true touch-less).
If you have the original tires still on the rims, Ford will look at the environment.
Mechanical car washes can booger up the clearcoat on rims exposing the aluminum to the environment.
Old 12-24-2018, 05:07 PM
vehicle year - 2014
location massachusetts
New tires
do not use mechanical car wash
Old 12-26-2018, 03:22 AM
Like any other salt belt state, Massachusetts uses rock salt, sand, calcium chloride and magnesium chloride for road clearing. Any little nick or breaching of the clearcoat (just a thin coating) on the rims and they will start to corrode as they are exposed to that type of environment. Been there with several different vehicles. Doesn't matter what MFG. From Ford to Mercedes.
Old 12-30-2018, 01:43 PM
Richard Gary Pace's Avatar
Have you used any tire / wheel cleaner
Old 01-31-2019, 03:39 PM
Reloader's Avatar
Default 1956 Victoria
Since we are talking rims, will the below rims fit my 1956 Victoria? Thanks!
AMERICAN RACING AR23 15x7 -6et Machine
  1. Part Number: AR235765
  2. Brand: AMERICAN RACING
  3. Model: AR23
  4. Finish: Machine
  5. Size: 15x7
  6. Bolt Pattern: 5x114.3
  7. Tire: 215/75-15 WINDFORCE PRIMETOUR 100T WSW
Old 04-04-2019, 12:18 PM
Madstork's Avatar
I have the SAME problem!! Owned mine for 4 years now, and they just get worse and worse! Is there any way to repair this?.....
Djcoak
05-07-2017 09:00 PM
Dually
12-03-2013 02:01 AM
Anthony Nguyen
01-17-2012 11:54 PM
johnc35ford
03-07-2007 06:47 PM
dared1
09-11-2005 12:12 AM
Quick Reply: Ford chrome 20 inch rims corroding
