light problem
my dome light will not go out with all the doors shut?
Could someone please help ?????????????????????????????????? |
RE: light problem
If it is a 96 or newer, spray inside the latches with a good lubricant. The door switches are located on the latch mechanism inside the door panel. Open and close doors a few times. Light should go out. If it has switch on body post, look at switch or wires to see if they are touching.
RE: light problem
mine wont come on whats up with that?
RE: light problem
head lights will not work. changed the bulbs. and even had it in the shop they could not find the problem. I am told it could be a maintenance switch. Can anyone tell me what a maintenance switch is and where it is located.
Would appreciate any help given. thanks |
| All times are GMT -5. The time now is 04:41 AM. |
