low idle @cold start
4.0 SOHC Idle runs 400 to 700 and wants to stall during first 1 - 2 minutes. Gas mileage is poor now maybe 12mpg. Have replaced IAC 8 months ago. Engine runs fine after 2 minutes with no loss of power. Sprayed carb cleaner around base of intake with no change. Someone suggested replacing coolant temperature sensor. I can see it but unable to get there.
Thanks |
RE: low idle @cold start
I have the exact same symptoms with the same engine except with check engine light.
Im taking it in for a diagnostic check. Ive heard o2 sensor or maf sensor but wont know for sure until I take it in. FYI I changed the fuel filter with no results. |
Hi John, What year is your Explorer?
I had purchased a used 1998 that was doing what yours is, and when I went to the dealer, I learned there was a recall for the head gasket. There was a heater switch, or something like that, I think, that was taken care of also. But that switch was not the cold start up problem, the head gasket was. And I did get a new spare tire because it was a firestone. I had them replace every hose, belt, and clamp while they were in there replacing the head gasket. I see there are a few posts around here, that sound like the same problem? Peace Out |
