Please help - Exp 200
I have a ford explorer 2000 - after being in 4 wheel drive for 5 mins to get out of a snowpacked carpark (in Denver) stopped, put in neutral then changed to all wheel drive - however in D the truck would only rev no movement will drive in 2nd and reverse and very slowly in 1st - any advice would be great . Thxs
RE: Please help - Exp 200
Is the od light flashing or the check engine light on. if so you mayhave a troulbe code in it. you may have to take it to a trans shop and have it looked at.If there is a auto zone near you may have them check and see if it has a trouble code and go from there. they will check it for free. Good luck
| All times are GMT -5. The time now is 08:28 AM. |
