-   Ford Explorer (https://www.fordforum.com/forum/ford-explorer-20/)
-   -   Power locks 94 Explorer (https://www.fordforum.com/forum/ford-explorer-20/power-locks-94-explorer-8146/)
da2962 May 8, 2007 11:16 AM
I have a 94 Explorer and am having a problem with the passenger side power lock button. About 6 months ago it just stopped working. The "master" control on the driver's side still works just fine but I'm unable to lock or unlock the doors from the passenger side. I took the switch apart and cleaned the contacts and it worked for a couple of days, then just stopped working once again. I haven't been able to find a replacement switch for it. Any suggestions???
91explorer12323 May 8, 2007 12:35 PM
RE: Power locks 94 Explorer
Ebay!!!! or a junk yard ,which ever. if you go to ebay just type in explorer power window and that should get you started in the right direction,,,
91explorer12323 May 8, 2007 12:37 PM
my bad i meant to have you type in explorer power locks when looking on ebay lol im tired
wheelsup68 May 9, 2007 12:45 PM
Junkyard or dealer unless part has been dsicountinued from Motorcraft
da2962 May 24, 2007 12:08 PM
Just to update on this. Looked around and found a couple sources for the power lock andwindow switches at local junk yards. Ended up bypassing the problem by installing a keyless entry system. Now I don't have to bother with the switch in the door, just hit the button on my keyring. This was something I wanted to do for a while, but just finally got around to it. Eventually I'll have to go ahead and replace the buttons for re-sale I suppose. Thanks for the replies.
