wont start 98 explorer
Old 08-18-2007, 02:27 PM
nino's Avatar
Default wont start 98 explorer
everything turning but no gas is coming out of the fuel line?i disconnected the line from fuel filter. help what could be the problem
Old 08-18-2007, 05:33 PM
haledonoem412's Avatar
Default RE: wont start 98 explorer
Sounds like the fuel pump. Listen when you put the key in the on position you should hear the pump kick on.Check the fuses and fuel pump relay to.
Old 08-18-2007, 06:39 PM
I you have been bumped in the rear you may want to check the inertia switch.
alanjlee
10-25-2012 07:15 PM
nflz32
05-10-2007 02:35 AM
ncruea
03-10-2007 05:06 AM
Green_Eye_Gurl2
05-15-2006 06:37 PM
Green_Eye_Gurl2
05-15-2006 04:17 AM
Quick Reply: wont start 98 explorer
