Rear Liftgate Glass Hinge
2004 Ford Explorer XLT rear liftgate glass hinge no longer opens. Please help.
Originally Posted by Nobounderies
(Post 132423)
1. Sensor problems - the liftgate sensor can go off/on because - a. the glass wobbling b. the hinges being compromised. c. The wires leading to the sensor are compromised. 2. Wear and Tear- Because the trunk button on the key fob controls the glass and not the entire liftgate it often gets released and people drive with the glass lock released. the glass then rattles (*a above) and can damage the release over time. 3. The key fob no longer works (recent upgrade or new one) or fuse needs replacing. What would you like help with specifically that is causing it not to open? The hinge? The release? The key fob signal/ fuse/sensor? |
Here is the Hinge you would need -
Here is the Liftgate Glass Actuator Here is the Liftgate Lock Actuator Here is the Liftgate Ajar indicator Switch Connector |
