-   Ford Explorer (https://www.fordforum.com/forum/ford-explorer-20/)
-   -   Rear Strut/Coil Assy Removal & Replace (https://www.fordforum.com/forum/ford-explorer-20/rear-strut-coil-assy-removal-replace-28821/)
HocusFocus Dec 24, 2012 05:06 PM
Can anyone out there provide instructions on how to replace the rear coil spring or the entire spring/strut assembly.
Is it better to replace the entire assembly, or coil spring.
I have a broken spring w/ ~145k miles and trying to determine what I want to do.
Thanks
hanky Dec 24, 2012 06:07 PM
Most of the time those springs break due to corrosion from road ice melting chemicals.
I $$ permits and with those miles on the vehicle best move is to replace the entire assy ON BOTH SIDES. A common problem in rust belt areas. Check the front ones too. A spring can break puncture the tire resulting in costs for towing, tire replacement and spring replacement. If possible , better to replace them before they break on the road.
Depending on the year the repair may be covered by a recall. What year is the vehicle?
HocusFocus Dec 25, 2012 08:16 AM
Thanks
It's a 02 XLT 4WD
bluewind Dec 25, 2012 10:48 AM
That's how it's done.
Have fun. Have the alignment checked when you are done.
