rear washer
2015 explorer rear washer not working.no power at pump plug.windsheild washer works after installing a new pump.had no washers working before pump replacement.
Does the rear wiper blade work correctly by itself?
Does the rear wiper blade work when rear washer is used? |
(Post 121604)
You need to specify if the rear wiper works when you use the rear washer or only when you turn the rear wiper to on.
yes the rear wiper works in wiper only mode or while your using the washer switch.
Ok if I understand you the rear wiper turns on when you try to use the rear washer. Here is the wiring diagrams and the fuse box, to start put the washer hoses back to normal.
Remove the highlighted relay from the fuse box and jump pins 3 and 5, check if the pump activates and sprays out the rear, if it does not turn on then check if there is 12V at pin 5 with the other voltmeter lead attached to the negative battery terminal. https://cimg0.ibsrv.net/gimg/www.for...d7d033e0f9.png https://cimg4.ibsrv.net/gimg/www.for...23df9912af.png https://cimg6.ibsrv.net/gimg/www.for...f77b263d9d.jpg |
thanks i pull fuse 82 and found it to be blown.tomorrow i will run to town and get a new fuse.i think when the original pump froze up it must have blown the fuse.thanks for the diagrams that did the trick.
@mark0359 Did replacing the fuse fix the issue or did the fuse blow again.
yes new fuse fixed the issue.thanks for the diagram of the fuse box ,that was my problem not knowing what fuse to check.thanks again for your help.
