rear wheel bearing
Old Jun 17, 2007 | 09:40 PM
jentner's Avatar
Default rear wheel bearing
I inquired about rear wheel bearings for my '03 V-6 explorer at a local auto parts store. I was told $186.00 perwheel. The say I need the whole hub assy and cannot just by the inner and outer races and bearing. I've never changed out wheel bearings for more than 50 bucks. Does this soundright?
Old Jun 17, 2007 | 11:54 PM
Default RE: rear wheel bearing
The rear bearing 'is' available without the hub..
But, thesuspension will need to be pulled loose at the pinch bolts, brakes, and the spindle will need to removed,, and will require some 'press time' to push the hub off/out of the inner race of the bearing, and then the bearing out of the spindles bore.. These are a double ball caged bearing, and being'wide' they don't easily push out,,, and the hubs yoke out of the bearing is usually an even harder push in most cases.. On install/assembly, it's critical to push/press on the correct area on the bearing or you can damage the bearings seal/s.. I know this
Here's a pic of the hub/bearing for bearing reference....
[IMG]local://upfiles/6756/3772CBF2F2784E47B4CC44287A1253CE.jpg[/IMG]
makuloco2000
Nov 9, 2014 11:44 PM
robcat
Sep 25, 2008 09:47 PM
dewdog1978
Mar 10, 2008 06:02 AM
five0stangman
Feb 29, 2008 06:46 AM
applmillane
Jul 19, 2007 12:48 PM
