recharge a/c
Where is the a/c low pressure port located on a 2003 explorer XLT? There is a valve near the compressor and one on the dryer, but neither seems to be the correct size flair fitting.
RE: recharge a/c
Do you have a 134a recharge hose?
RE: recharge a/c
Yes
RE: recharge a/c
Ok the hose adaptor will olny fit on the low side .It should be by the reciver/Dryer.Remove the cap slide the adaptor sleve up and push on.
RE: recharge a/c
Yes, it's a interdynamics trigger model with built in gage, it is not the refrigerant 12 screw on type.
RE: recharge a/c
thanks 4/4
| All times are GMT -5. The time now is 10:34 AM. |
