Replace Serpentine Belt
How do I replace the Serpentine Belt on my 2002 Ford Explorer V6?
RE: Replace Serpentine Belt
Fairly simple job...
On the belt tensioner, out close to the belt pulley(black arrow) there is a square slot for a 3/8 drive.. Genrerally you can insert a ratchet (longer 'flex head' type work well), or short 3/8 breaker bar into the tensioner slot.. Rotate CCW to take the tension off the belt and slowly release the hold on the bar/ratchet.. Then just feed a new belt over the drive components as show below.. Your 'belt routing' will/should be shown on the underhood decal as well.. Once in place, then repeat the belt tensioner load.. You can buy a tensioner tool, but most times you can improvise with basic tooling.... [IMG]local://upfiles/6756/8567B88483844D6D866AB6C142806491.gif[/IMG] |
| All times are GMT -5. The time now is 03:02 AM. |
