right front vibration
i notice im getting vibration at city speeds but when i get on hiway it does not sound so bad im also getting inside tire wear on passenger side there is 135,000 km on explorer ,vibration around passenger feet
RE: right front vibration
[sm=welcomesign.gif] The front vibration is it bump related?
nope continueing thump thump thump etc i get vibe near driveshaft i also get it when its in neutral coasting on road
The vibration around passenger feet I would say it is a worn radius arm bushing.The tire wear is do to front end wear and may possibly have a bubble in the tire. I would rotate the tire'a and see if the problem disapear's to the rear. I may also be the U joint's in the driveshaft.
ok i will get on it on friday after work thanx for the info ps is the radius arm a bich to change .as the ball join,t or is it easier to do
i would say not driveshaft cause it does it in neutral i thought so too till i tried the neutral trick thanx
The ball joint is a pain in the ass too[:@]If you plan on replacing them buy the upper and lower.As for the radius arm bushing's you will have to grind the factory rivet's down and punch them threw and use hardend steel bolt's and lock washer's when replacing.Real pain[:@]
to bad you are not in toronto canada cause i would let u chek it out haahahah thanx again
The best advice I can give you is right here:)Im in PA
| All times are GMT -5. The time now is 03:13 AM. |
