Switching to 4x4 Doesn't Work
Old Mar 19, 2011 | 08:32 AM
rlj50's Avatar
Default Switching to 4x4 Doesn't Work
2004 Ford Explorer XLT - AWD
During a recent snow storm I tried switching from all wheel drive to 4x4 High, unfortunately I was unable to get the transmission to switch into this gear or even the 4x4 Low gear. When I attempt to switch into either one of these modes nothing happens. I get no indicator light on the instrument panel or the small indicator light on the 4x4 Low switch. I've replaced both the high current fuse and the 5A fuse under the driver's side dash associated with the 4x4 function (using the owners manual). Niether one of these fixed the problem. Any suggestions on what to try next (other than taking it to the dealer)? In the four years I've had the vehicle this is only the second time I've tried switching into the 4x4 High or Low gear. The other time was just after I purchased the vehicle and it did work then. Thanks! RLJ50
Old Mar 19, 2011 | 08:24 PM
PLEllis's Avatar
check and see if getting power to motor on transfer case if you are motor maybe stuck you can try jaring it to see if it will come unstuck they tend to stick if not used
Old Apr 8, 2011 | 03:55 PM
twinzer's Avatar
i agree .power supply problem.i usually dissconect the power for 1 min.then plug it back in .usually works on mine.
Old Apr 9, 2011 | 07:51 AM
rlj50's Avatar
Twinzer, Where do I disconnect the power supply? Thanks!
RLJ50
rlj50
Mar 16, 2011 08:23 AM
MGood777
Aug 2, 2010 09:53 PM
andydevries12
May 17, 2010 10:02 PM
Thacashstream
Dec 10, 2009 05:55 PM
opie4487
Jul 10, 2008 06:34 PM
