TRACTION -LOK AXLES?? HELP!
Hey guys i was just wondering if anyone knows off hand if a 91 explorer xlt 4wd has traction- lok axles?? the reason i ask is im draining and putting new differential fluid and it says to add friction modifier when changing the diff. fluid if the truck has these traction-lok axles. any info would be appriciated greatly
RE: TRACTION -LOK AXLES?? HELP!
Whats the axle code on the certification label in the door jam?
The axle code for this Suv is 45
Code/45
Description/Open (Non L/S) Capacity 3200lbs Ratio 3:55 |
Thanks for the info Haya!
