Transmission Slipping!
Hello, I have a 2002 Ford Explorer XLT, 4.0L V6. It has the 5R55W transmission. The other day out of nowhere it started slipping like crazy in reverse and overdrive. I checked the filter and it was nasty and clogged so I changed the filter and fluid, but it didn't help the issue. Could this be caused by a bad solenoid in the solenoid pack or is this a mechanical issue? I assume that if it were a problem with the solenoids that the engine light would be on but I am unsure. If it's a mechanical issue what could it be? This is very urgent for obvious reasons. Any help with this situation would be greatly appreciated, Thanks!
Subscribed for answers to the questions above... These trucks are notorious for transmission problems. (2002 Ford Explorer Problems, Defects & Complaints)
btbell0615
Sep 16, 2012 05:27 PM
