genius117 |
02-21-2009 05:21 AM |
1985 F150 Valve Cover Leak
Ok y'all, So I just purchased a 1985 Ford F150 4x4 V8 with manual transmission that is fuel injected. There was a bad leak on the drivers side valve cover. So I took off the fuel injector setup off the top of the engine, removed all the necessary vaccuum hoses and electrical hookups and got the valve covers off. I put on new valve cover gaskets and hooked them into the cover with the tabs. my problem is that I get mixed info about using a sealant of sorts to seal the gasket to the valve cover before I bolt it back down. So this time I didnt use any I just slapped everything back together. I now have more then one leak from the valve cover gaskets. I tightened them down evenly, tightened them till they were snug and then went another 1/4 turn. Please help me stop this leak. Oh just so you all know. I am mechanically smart enough to follow directions and install stuff but I am not up on the technical terms or proper enginge part names.
