1993 F150 Ignition Switch Replacement
How hard is it to replace switch and does steering wheel have to be removed to replace turn signal/wiper delay switch? Thanks!
It is easily replaced. The steering wheel does not have to come off. If it has tilt, remove the tilt lever. Then remove 3 screws under the lower steering column cover. Threr are 2 little torx headed screws that hold the switch in place. Remove the screws, unplug wiring and replace switch.
Is the ignition switch easy to replace, I've been told just to move switch to run position and use small drill bit in hole under ignition switch (shroud) to release pin that holds in ignition switch and switch pops out?
If you are talking about the key cylinder, you have the correct procedure.
Thank you for your help!
