1995 ford f150 front brake hose question
Well i have to work on a 1995 ford f150 4.9 4wd.My question is i have to change out the front brake hoses.Is this job hard?Everything looks rusty so i expect it will be twice as hard.
I expect you will not be disappointed.
If you clean the upper hose fittings and soak them a while it may make the job of loosening the tubing nut a little easier. The right size tubing wrench makes the job a lot easier too. |
