2000 F150 Auto Trans into 2001 F150
I have a 2001 F150 4x4 with 4.6 Triton. Transmission went bad. Transmission Tag numbers are as follows,
PKF-CP 1L3P-7000-HA 1P 040929 A friend has a 2000 F150 4x4 with 4.6 Triton with a good transmission.. Transmission Tag is as follows PKF-CR2 1L3P-7000-JA 1R 147515 Both are Autos... Will the one from 2000 Fit into the 2001? |
On the driver's door pillar should be a label with build info on it. What are the trans codes for each if the two vehicles?
(Post 112333)
Both Trans Type “U”. |
It would appear that you should be able to use either trans.
