2002 5.4l spark plug change
I have just had a misfiring problem that got fixed when I changed my # 8 coil. I now have 84,000 miles on my truck and am going to replace the spark plugs myself instead of paying for it to be done. The problem that I am running into is the coils that are connected to them. I am looking for any info on how to remove the coils without damaging them. Any help would be greatly appriciated.
RE: 2002 5.4l spark plug change
:eek:Dunna,,[&:] just very carefully :D
Yeppers , [sm=goodidea.gif]
If you have the coils that sit on top of the plug, they are actually not that bad.
There will be a small bolt that holds them in place. After disconnecting the clips to the injectors and the coil itself, undo the bolt. After that the coil should lift out with a boot still attatched. You can then get to the plugs. Do the reverse after changing the plug |
