2006 f150 transmission fill tube bolt thread size/length
Have a 2006 f150 2wd 5.4 with fill tube bracket bolt to head missing. It's a very large bolt hole, so probably 1/2 or larger idk. I need diameter, thread pitch, and length please. Hoping someone has checked it before or been through it. Searched ford parts and Google to no avail.
There is a simple way to obtain the correct part.
Check with your local Ford dealer ship parts department and they should be able to come up with the correct bolt for this problem. They will need your VIN. |
Not simple, tried 2 dealerships and neither could locate it. I even tried through ford.com and not even on the diagram or parts lists anywhere.
Every dealership parts dept has `a microfilm available for just about every vehicle they make.
If the gents working there don't know how to pull up the pix and description, you may need to try a dealership that knows how to do it. |
