2015 F150 keypad programming
I purchased the ES7Z-14A626-A keyless entry keypad from my local dealer for my 2015 F150 that has keyless entry and it contains no instructions to program. I searched for instructions but couldn't find anything that worked. any help,
Thanks
Thanks
Welcome to the site..
Wireless Keyless Entry Programming:
When programming an alternate code into your key pad, make sure you have your Keyless Entry factory code in hand and the 5-digit number you want in mind.
Lock all the doors and enter in the 5-digit factory code.
Within five seconds press the 1/2 button.
Within five seconds of the doors unlocking/locking, enter in the 5-digit code you wish to use.
Once you’ve entered the new code wait for the confirmation (unlocking/locking of the doors) to know that your new code was accepted.
Test to ensure your vehicle has accepted the new key code.
If model Equipped:
Programming with MyFord Touch
If your vehicle has the MyFord Touch system there are two separate ways to program your Keyless Entry Code. The first was described in the section above, the second involves using the MFT (MyFord Touch) screen from within your vehicle.
Begin by pressing the “Menu” button located on the top of the Home Screen.
Click “Vehicle” located on the left menu list.
Select “Door Keypad Code” from the list.
Enter in your factory key code.
Then enter in the 5-digit key code of your choice.
Once completed your Keyless Entry code will be changed allowing you to use that code to enter your vehicle.
Easter Eggs
Your Keyless Entry Key Pad can do more than just unlock the driver side door.
Once you enter in your key code press button 3/4 to unlock all doors
If you press button 5/6 after your key code is entered it will open your lift gate if you vehicle is equipped with one.
Instead of fumbling around with your keys to find the lock button just press button7/8 and 9/0 at the same time to lock all your doors.
If model Equipped:
Easter Eggs
Thank you, but I am looking for instructions for connecting a wireless keypad with my 2015 F-150. I have have read most of the instructions on line which require a sequence starting with unlocking the door and quickly cycling 8 stop-runs with the key, but none of the attempts work.
Your trying to program in a wireless touch keypad to a truck with Remote Entry only,
correct?
Keypad is not attached to the door, correct? Better to have it in on your lap etc. and the fobs ready to program all at the same time, starting with the fobs.
S/B
Unlock the the vehicle electronically (fob) or the door unlock button.
Put the key in the ignition and cycle the key on/off to Run, eight times with 10 seconds leaving it ON on the eight cycle.
Door should lock and unlock to confirm programming mode.
Which in 20 seconds, press any fob button on first fob,, should get a lock/unlock confirmation.
Repeat again within 20 seconds for key fob two, again, should get the lock unlock confirmation.
Within another 20 seconds of the last key fob, Press the 7/8 and 9/0 keypad keys 'simultaneously. Locks should again cycle to confirm the pad is programmed..
correct?
S/B
I have two keys that are programmed. I have part KB3Z-14A626-A and it won’t program the regular way. It did come with a card. I have Forscan but I do not see where you can enter codes into BCM? Help. I want this programmed …I need help
2012 Ford Mustang GT
93Miata
Nov 11, 2005 04:42 PM
