2020 Ford F-150 Limited Pickup
Just recently purchased a 2020 Ford Limited F-150 Pickup and so far I really like it. I only have 2,200 miles on the truck and noticed a situation that has not come up before. Since I have owned the truck (February,2020) I have always had the "Digital Speedometer screen set to "Digital Speedometer" and every time I have parked the truck and turned off the ignition and then restarted the truck the "Digital Speedometer" screen would come up like it should and every thing worked fine. The last week something different has happened. When I have the "Digital Screen" set to "Digital Speedometer" and turn off the trucks ignition and then "restart" the truck the screen that pops up now is the "trailer display screen" even when I do not have a trailer hooked up. I do not want this screen to come up first, as I want the "Digital Speedometer Screen" to come up. The way it is doing now, the "trailer Screen" appears and won't go away until I manually move to the "Digital Speedometer" screen, but once I drive the truck, turn off the ignition and get back into the truck and start it up the "Trailer Screen" appears.
Has anyone else out there experienced this happening? If so, can you help me out to get this from doing it? Thanks so much. Bwinters |
Welcome to the site..
On the trailer options, delete the stored default/trailer |
Thanks so much, this seems to have taken care of my problem. I sure appreciate your help.
