2wd to 4wd
Old Nov 4, 2017 | 01:07 PM
ClaytonK's Avatar
Default 2wd to 4wd
I have a 1991 Ford F-150 4x4 with a 302. I'm trying to take the frontend, transmission, and transfer case and put in a 1996 Ford F-150 2wd with an 300 inline 6. So my question is will the transmission and transfer case work coming from a 302 to a 300 inline 6. I'm pretty sure the front end will slide in without a problem. Or if the transfer case would bolt up to the transmission I already have in my 1996 Ford F-150.
Old Nov 6, 2017 | 08:01 PM
ClaytonK's Avatar
Default Nobody knows anything ?
I guess no one knows??
Old Nov 6, 2017 | 10:27 PM
Welcome
5.0 and 4.9 use the same bell housing pattern. T case alone wouldn’t be a bolt on component on 2wd.
You never mentioned manual or auto trans , but the flywheel-flex plate would be different weight and balance from the 6 to 8.
yummyshortcake
Jun 8, 2007 11:50 AM
bikesandcars
May 1, 2007 01:47 AM
dannyf150
Feb 27, 2007 06:16 PM
mudpusher94
Jun 5, 2006 04:38 AM
nicholsmf
Oct 29, 2005 08:03 PM
