-   Ford F-150 (https://www.fordforum.com/forum/ford-f-150-14/)
-   -   351w timing issues (https://www.fordforum.com/forum/ford-f-150-14/351w-timing-issues-17537/)
crk_05 Jul 6, 2009 11:23 PM
351w timing issues
ok, here is what i have. It is a 351w bored .030 over, running 11.4.1 compression, patriot freedom heads, a lunati cam--Advertised Duration (Int/Exh): 262/270 Duration @ .050 (Int/Exh): 211/219 Gross Valve Lift (Int/Exh): .541/.549 LSA/ICL: 112/108--full roller engine, an edelbrock 1000cfm throttle body and 30lbs injectors, runs 15in of vacuum @ idle @ 3000ft. I am having trouble setting the initial timing on the engine. I have to get it to almost 40btdc to get the power curve that i need and for it not to run too rich, and it is also not pinging throughout the power curve. I have an ajustable regulator and set the pressure lower to lean it out. It has a eec IV computer that is speed density. I also tried the factory 19 lbs injectors and that helped out the "rich" problem, and i can manage to run the engine at 10-14 btdc, but it is lacking in the throttle response, backfiring through the exhaust, and very hesitant when you step on the throttle. I have set the tps sensor to .91 v closed, tranny still shifts a little to early though, e40d, least of my worries at the moment though. any help would be great on the timing and also the trans issue.
mustangmitch2010 Nov 8, 2009 11:16 PM
get a timing gun and hook it up or take it to a mechanic so they can do it.......you would probably be better off having a mechanic do it. It takes like 5 minutes to set it right
Bullitt94 Nov 9, 2009 04:49 PM
Are you removing the spout before checking and adjusting the timing?
