90 f150 4x4
Front end vibrates violently and right front binds and grinds when backing up. I have replaced the front shocks. Could this be caused by a bad ball joint?:confused:
That is possible.
Does it do this all the time, or only when in 4wd? Do you have manual or automatic locking hubs? |
No, only occassionally and only in 2wd. However, I don't use 4wd at the speed it vibrates very often so I don't know if it happens in 4wd. It was auto lock but recently converted to manual locking hubs. If it starts grinding when backing up, I pull forward a little bit, back up again and the bind/grind goes away.
You may want to see if you have something hung up in your breaks. That could cause these symptoms.
