93 lighting fire to coil / no start
i replaced all ignition parts i am aware of and i have no fire after the coil. please help
Is the coil new, too?
How have you diag'ed the ignition system? One side of the coil will have fire from the igniiton switch, the other side will close ground to saturate the coil and fire it. You should have a constant light on one side and a blinking light on the other side with the engine turning over. To do a proper test and remove the ECM from the circuit, you should disconnect the spout wire at the distributor.
