96 f-160 egr pressure sensor
Old Jul 23, 2005 | 08:41 PM
philip graham's Avatar
Default 96 f-160 egr pressure sensor
I pulled code p1406 on 1996 f-150 with a 5,0 engine. I checked online and got some info that it would be a downstream hose loose, plugged or bad dpfe. I went to the parts store and bought a new dpfe just in case. The problem is I can not find anything that lookes like the part that was sold to me. Where is the dpfe sensor. A picture would be great.
Old Jul 24, 2005 | 01:33 AM
Default RE: 96 f-160 egr pressure sensor
I found it. It sure wasn't where I thought it would be. I will chang the sensor out tomarrow.
Old Jul 24, 2005 | 12:12 PM
hockeyhitman69's Avatar
make sure you check your hoses connecting to it as well
Old Jul 24, 2005 | 01:23 PM
Ramrod48's Avatar
Yea, the old ones were a gray / sliver color , The newer ones are black , 2 hoses an a wire connector , be careful with the hoses an plug them back it the correct port , ( Ive seen guys hook them up wrong ) disconnect your battery for like 5 min. then test drive , good luck
fordwoman99
Mar 3, 2013 05:24 PM
dennis99
Oct 27, 2009 07:44 PM
FireMedic5001
Oct 26, 2009 04:43 PM
FireMedic5001
Oct 15, 2009 07:32 PM
ugly taurus
May 4, 2009 03:54 PM
