-   Ford F-150 (https://www.fordforum.com/forum/ford-f-150-14/)
-   -   98 f150 303 code (https://www.fordforum.com/forum/ford-f-150-14/98-f150-303-code-18336/)
gspaniel Sep 28, 2009 06:34 PM
98 f150 303 code
My 98 f150 has a miss on cylinder 3 [ code 303 ] i have changed wires , plugs ,coilpack , and the injector with no results . Does anybody have an idea what it could be ? The compresion is good on all cylinders .PLEASE HELP
way2old Sep 29, 2009 06:27 AM
Do you have the correct information posted?? Or just a typo?? P0303 is cylinder number 3 misfire.
gspaniel Sep 29, 2009 04:39 PM
sorry you are right its cylender 3 . Dont know what I was thinking
way2old Sep 29, 2009 06:22 PM
What size engine? The V8 is known for losing a cam follower causing a misfire. Is it still missing or is it just the code coming back? What is the compression readings on all cylinders? Sorry for the questions.
romeodz Oct 16, 2009 08:52 PM
If its the V6, verify you are not also loosing engine coolant. My 1997 and a misfire code along with coolant loss and I had to replace the lower intake manifold gaskets. Basically a 4 to 5 hour job.
gspaniel Oct 22, 2009 12:17 PM
v6 4.2 lower manifold gasket leaking coolant into cylinder1and3 found it when i checked compression Thanks for the help
way2old Oct 22, 2009 06:38 PM
Thanks for the fixed post. We do not get that enough.
romeodz Oct 24, 2009 03:32 PM
No problem.. This site is where someone told me what was wrong with my engine. Glad to hear your running again.
romeodz
