blower motor issue
Blower motor stopped working in my 2010 F150
king ranch which has the dual climate control. Replaced motor and still nothing i have power at the plug of the motor but it will not work need help! |
With Ford, they use the ground side to control the operation.
Did you check all the fuses? HVAC Control module has to have power to work If you provide a temporary ground to the motor other wire it should run, does it? |
Bad blower
Have you tried replacing the blower motor resistor? They have been known to corrode and that makes blower motor either work only on one speed or not operate at all. |
