Sponsored by:
Sponsored by:
Rims and tires
Old 03-08-2011, 06:49 PM
PAULXLT92''s Avatar
Default Rims and tires
Hey everyone I'm pretty new at this forum thing, I'm 18 an have a 92' f-150 XLT with a 5.0, stock. I'm looking to put some 15x8 American racing rims on it and I'm wondering what a good offset is for the rims. I found a set that has a -12 offset. Is that to much? Also I'm loYou add 1" to the rim width to account for the wheel flange (pictured below) because there is a 1/2" space on each side between the wheel flange and inner lip. The actual width of the wheel is measured from wheel flange to wheel flange. So if your wheel is a 15x8, the 8 (width) is measured by the wheel flange and not from outside lip to outside lip. oking to put 31x10.5 tires on them, is this a good size and will I need to put in lower gears and change the speedo?
Old 03-08-2011, 10:47 PM
Bullitt94's Avatar
Well, your stock tire width is 9.25in and you are looking to put on 10.5in wide tires. I would venture to say that the .63in difference per side of tire width won't hut you any on a stock rim. So if you use your stock rim offset I would think you would be O.K. If you want to be safe, add an inch to the offset. It will more than compensate for that difference.
Old 03-09-2011, 06:43 PM
PAULXLT92''s Avatar
Thanks bullit94, I'm looking to put 15x8 rims on there an I believe that the stock rim size is 15x7. So that extra inch offset might really help, thanks.
DreamF150
07-12-2010 04:53 PM
genius2envy
09-05-2008 05:38 PM
rollin1expo
12-27-2007 02:10 AM
OffRoadF250
06-23-2007 08:07 PM
josser
06-05-2006 04:40 AM
Quick Reply: Rims and tires
