Clutch Problems Help ASAP!!!!
Old Feb 14, 2009 | 09:14 AM
Leandro's Avatar
Default Clutch Problems Help ASAP!!!!
All of a sudden my clutch started acting very weird. The clutch feels like butter most of the way down then it catches some pressure at the end for about like 3 or 4 inches. Last night I bleed the slave with my brother and dad. It was working good and driving perfect after we finished but about an hour later I went to drive the truck and it was the same thing no pressure.
The truck is a 2000 F150 with a 4.2 V6 manual transmission
What do I do??
I think im just going to try the bleed process one more time and bleed it all the way this time
Old Feb 25, 2009 | 09:33 AM
coford's Avatar
I had the same problem about a month ago. i went to my local hobby shop and used a vacume pump to force all the air out of the master/slave hoses. after recealing it and keeping the fluid level from drying out. it began to work with no problem. occasionally, when it's cold, the pedal will be a bit soft. does your clutch engage after you pump it a bit?
Old Feb 26, 2009 | 11:19 PM
Leandro's Avatar
Hey thanks for the reply i basically did the same thing but i did it the old school way. I had my dad pump the clutch and hold it while i bled it from the slave bleeder. I also had to replace my master cylinder and clutch safety switch but now everything is running great! thanks for you help
Old Feb 27, 2009 | 07:37 PM
miblueracer's Avatar
try bleeding the system again it may still have air, it sounds like an 89' f-150 4x4 I had.
Is it leaking fluid?
cyberrkatz
Jul 7, 2010 09:46 PM
KINGDELL
Apr 13, 2008 10:01 AM
TAB999
Aug 26, 2007 01:23 PM
SuperFord73
Apr 26, 2007 07:59 PM
Silverrr
Dec 19, 2006 10:29 PM
