Cracked transmission
2001 F150 4.6
I am burning a bit of motor oil, so crawled under to find a crack in the transmission! I see no leak at all on the ground or on parts, but a crack in the transmission. 1. Why am I burning alot of oil? No puddles underneath 2. Can I JB Weld repair the crack in transmission? My transmission fluid hasn't moved, no leak 3. Are they related...or just my bad luck? Thanks! |
Can you give some more info as to just where the crack is located and it's size?
Or a pic if possible..
