Drivers outside mirror
I have 2019 F150 my driver outside mirror sometimes bounces and moves when i start the truck, not all the time. I than have to adjust the mirror each time this happens, anybody have any ideas?
Originally Posted by vsf150
(Post 141029)
Looks like after fixing things up, something might not be hooked up right. Check all those vacuum lines you worked on to make sure they're in the right spot and tight. Also, give those new spark plugs and wires another look to make sure they're all connected right. If something got knocked loose while you were working, it could be causing the trouble. And with the smog pump lines cut, make sure that's not letting air in where it shouldn't. A little air leak can cause big problems. Hope you get it sorted out! Catch you later! |
