engine swap
Old Jul 19, 2005 | 03:12 PM
F 150 Bama's Avatar
Default engine swap
I have a 2000 f150 4.2 v6 auto 355 rear end .i would like to put in a larger motor . I toe a travel trailer and would like more power. Can another motor bolt up to my trann, what about computers, elect. and any thing els thanks
Old Aug 18, 2005 | 10:54 PM
onelow48's Avatar
Default RE: engine swap
I have a 1997 ford f-150 supercab 4x4 with a 4.6 liter,it recently blew up.I bought a 2005 ford 4.6 liter engine,is there anything i should know about this swap far as changing ,wireing harness, manifolds,sensors, pulleys ect. I need you HELP in this swap
Old Aug 19, 2005 | 04:35 PM
cctxfish's Avatar
4.6 to 4.6 should just bolt in. the v6 to v8 swap I just don't know, my guess is it will bolt to tranny but the electrical donno
Old Aug 19, 2005 | 07:25 PM
Ramrod48's Avatar
yea going to a bigger motor , you will need that eng, puther , to go along ,an the newer vechiles the tranny's shift points are controlled by puther also,, On the more current vechiles I cant really tell you point by point , , But we put a 302 an a AOD in a Bronco 2, 1987 model, it had the 2.9 liter an forget the tranny., But yea had to change to 302 puther an do a lot of wiring schemic reading an splicing , put a rear axle outta a 150 in it , of course had to shorten the axle tubes too , the drive shaft was funny looking , only about foot long , But it sure would pull a boat trailer !!!!!
Old Aug 19, 2005 | 10:45 PM
cctxfish's Avatar
Yea thats right and your going to need all the wire harness for the extra cylinders. Its best to have the whole car there to pick and take.
Old Aug 20, 2005 | 02:06 AM
Ramrod48's Avatar
Yep get an every thing you can think of , Even if you dont use it , Exhast system, 02 sensor, Drive line, Diff yoke, You going to need a camera, several rolls of film, a digtal would be best.
Get a good note pad, get some wire markers , there a sheet of # stickers, for wrapping around wires , hoses ,, You can get them at Radio Shack, Well worth the cost of a few bucks for several sheets, an diff colors, I think even Home Depot carries them now if I remember rite.
bmwrocks03
Apr 21, 2008 09:29 PM
matt95ssei
Apr 5, 2008 02:15 PM
bluefordalways
Jul 29, 2005 03:32 PM
92FlareSide
Jul 1, 2005 02:30 PM
fordmann67
May 8, 2005 09:22 PM
