engine swap
I have a 2000 f150 4.2 v6 auto 355 rear end .i would like to put in a larger motor . I toe a travel trailer and would like more power. Can another motor bolt up to my trann, what about computers, elect. and any thing els thanks
RE: engine swap
I have a 1997 ford f-150 supercab 4x4 with a 4.6 liter,it recently blew up.I bought a 2005 ford 4.6 liter engine,is there anything i should know about this swap far as changing ,wireing harness, manifolds,sensors, pulleys ect. I need you HELP in this swap
RE: engine swap
4.6 to 4.6 should just bolt in. the v6 to v8 swap I just don't know, my guess is it will bolt to tranny but the electrical donno:eek:
RE: engine swap
yea going to a bigger motor , you will need that eng, puther , to go along ,an the newer vechiles the tranny's shift points are controlled by puther also,, On the more current vechiles I cant really tell you point by point , , But we put a 302 an a AOD in a Bronco 2, 1987 model, it had the 2.9 liter an forget the tranny., But yea had to change to 302 puther an do a lot of wiring schemic reading an splicing , put a rear axle outta a 150 in it , of course had to shorten the axle tubes too , the drive shaft was funny looking , only about foot long , But it sure would pull a boat trailer !!!!!
RE: engine swap
Yea thats right and your going to need all the wire harness for the extra cylinders. Its best to have the whole car there to pick and take.
RE: engine swap
Yep get an every thing you can think of , Even if you dont use it , Exhast system, 02 sensor, Drive line, Diff yoke, You going to need a camera, several rolls of film, a digtal would be best.
Get a good note pad, get some wire markers , there a sheet of # stickers, for wrapping around wires , hoses ,, You can get them at Radio Shack, Well worth the cost of a few bucks for several sheets, an diff colors, I think even Home Depot carries them now if I remember rite. |
| All times are GMT -5. The time now is 08:16 AM. |
