engine swap
Old Apr 25, 2005 | 12:02 AM
fordmann67's Avatar
Default engine swap
I currently have a 1994 F-150 4x4, auto, 5.0 fuel injected............wondering if a 1986 Bronco 5.0 fuel injected would fit in the truck? The truck has a serpentine belt set-up and the Bronco has a regular V-belt. Will accessories...A/C pump, alternator and power steering pump bolt on to the Bronco engine? Any help would be great, have the oppurtunity to get a heck of a deal on a rebuilt engine with really low miles and don't want to pass up a good deal!!!!!!
Old Apr 25, 2005 | 03:50 PM
skip's Avatar
Default RE: engine swap
Yes a 302 is a 302. A few differences that you might find are:
1. Some of the older 302's required long reach plug because the cooling ports in the heads are larger (autolight 25-45 instead of the 45)
2. The top bolt of your 94 accessory assembly will be smaller than the hole in the block (just get a hixa coil)
3. The cam is probably slightly different but your 94 computer should adjust for the difference.
Old May 8, 2005 | 09:22 PM
Hawn's Avatar
I have a '66 Bronco with a 289. Edelbrock (weber) Carb. Performer intake manifold. Anyway, I try to start it and it backfire through the carb. Any suggestions would be helpful.
The Hawaiian
bmwrocks03
Apr 21, 2008 09:29 PM
matt95ssei
Apr 5, 2008 02:15 PM
F 150 Bama
Aug 20, 2005 02:06 AM
bluefordalways
Jul 29, 2005 03:32 PM
92FlareSide
Jul 1, 2005 02:30 PM
