Ford F-150 4x4
I have a 1999 4x4 Ford F-150. The 4-wheel drive will not engage, and I dont have a manual to check the relay. Does anyone have a maual for this year of truck? I only need to knowwhich relay under the hood is my 4x4 relay.
RE: Ford F-150 4x4
You could get a Haynes Manual for about $16 that will have it in there.
RE: Ford F-150 4x4
http://static.howstuffworks.com/gif/...-trucks-37.jpg
I have a 2007 Ford 200 Ford XLT F-150 FX2 Sport and i dont know if this manual is compatible for your f-150 but i've got this to truck parts online when i am searching for a manual. |
RE: Ford F-150 4x4
What you might try is with some one in the truck key on foot on the brake trans in neutral engine not running tap lightly on the shift motor on the transfer case and see if it will shift, if it does you will hear a loud click. Some times when thease or not used very offen they will not shift. they tend to stick. good luck
