hanky |
09-11-2010 06:37 PM |
If my memory serves me correctly, there is a circuit breaker in the headlight switch assy. That is very well what is causing your problem. If you can manage to get the headlite switch out and unplug the plug with the wires from the switch and manage to jump the hot lead to one of the headlite wires and the lights work without flashing, it would confirm the problem. Also if I remember correctly the left side corner of the dash where the switch is located just pops off with a little careful prying. There is a little button underneath the switch that you depress with the headlights on and you can remove the switch stick. Actually you may even be able to feel the breaker working once you get the switch out and in your hand with the lites on of course.
