Heat/Air Conditioner Setting Knob
The knob to regulate the fan for heat and air conditioning only works at full blast now. I need to replace the switch but wonder if anyone has advice on how to remove the knob without causing damage.
Kind of late since you posted awhile ago, but the knob just pulls off. You have to wiggle it a bit, but it will come off.
Before you go replacing the switch, check the resistor body . That is in the circuit for all speeds except hi which is controlled by a separate relay.
