help with clutch 2001 f-150
ok the slave cylender broke and it sprayed oil al over the clutch so i put it in the shop and has new clutch and ss put in it but now the clutch pettle is verry soft nit like it was hard so i took it back to the shop and they say that is how it is i think there is air stil in the lines will this work it way out or am i just stuck with a verrrrry sofe clutch pettle? also when u out the clutch pettle to the floor as soon as u come up off the floor it grabs not like it was has a lil before it grabed ... he said they bled the system but i dotn think he benched bled the s/s should of he?ty for any info -
RE: help with clutch 2001 f-150
oops sorry its on a 2001 f-150
I would say that if there is any air in the system that it should work its way to the top??? I am no pro, but a new clutch is most always gonna feel different that your old one.
Mike |
My first thoughts would be "Why did it fail as soon as it did?" Then I would think, Is it working as it should ? As the other post mentioned..After a change, it will be different. I recently changed the clutch, pressure plate and throw-out bearing in my brother's truck. He noticed a change but is happy with the trucks performance. My question is...Did they change the throw out bearing.. If they did not, it might be sticking...Your coment about the clutch pedel kicking back indicates that it might be sticking or miss alligned. Your other coment about air in the system should not cause the kick back. However, after 40 or so years working on cars, I have witnessed odd things happening that I am unable to explain. Carl
