-   Ford F-150 (https://www.fordforum.com/forum/ford-f-150-14/)
-   -   High idle between shifts HELP! (https://www.fordforum.com/forum/ford-f-150-14/high-idle-between-shifts-help-19925/)
Shayne0 Apr 17, 2010 03:37 PM
i have a 1990 f150 5.0, 5 speed.In between shifts the idle jumps to a higher RMP if i shut the truck off and restart it, it seems to be fine like some kind of sensor is being reset?? pleaseeee help its annoying!could it possibly be the IAC????
Bullitt94 Apr 19, 2010 08:46 AM
Wouldn't hurt to try cleaning the IAC.
I am assuming this is a manual transmission as it revs betwwen shifts. May not hurt to clean the throttle body out as well to make sure the butterfly is closing properly when you let off the gas to shift.
